AutoCAD MEP General
*Raj
Message 1 of 7 (92 Views)
SP1 for ADT2004 modules of ABS
92 Views, 6 Replies
07-23-2003 03:38 AM
I have tried the SP1 update for the ADT components of ABS2004, refuses to
install. Is there a separate one for ABS ?
-Raj
*[Autodesk], Peter Terwilliger
Message 2 of 7 (92 Views)
Re: SP1 for ADT2004 modules of ABS
07-23-2003 11:43 PM in reply to: *Raj
Hi Raj -
We have not yet released an SP1 for Autodesk Building Systems. The ADT
service pack is for ADT only.
I hope this helps!
"Raj" wrote in message
news:628263B4CAA053EA7010A1847A172509@in.WebX.maYIadrTaRb...
> -Raj
*Jim
Message 3 of 7 (92 Views)
Re:
07-23-2003 11:46 PM in reply to: *Raj
Peter, Are there any ill effects if I have both ADT2004 & ABS2004 on the
same machine, and I install SP1 on my ADT2004?
-jim
*3design, Caleb |
Message 4 of 7 (92 Views)
Re:
07-25-2003 12:34 AM in reply to: *Raj
The only illnes you could expect is a full hard disk. Oh... wait. I'm the
only one working on laptop here... :smileysurprised:(
"Jim" wrote in message
news:740D61204BEC6CBE22BEA4AFAEF9734C@in.WebX.maYIadrTaRb...
> Thanks,
> -jim
*Smith, Jon
Message 5 of 7 (92 Views)
Re:
07-25-2003 01:54 AM in reply to: *Raj
I've been wondering the same - I presume the service pack updates files in
the shared directory that is used by both ADT 2004 & ABS 2004, but won't be
updating the files in the application's directories - thereby semi-patching
ABS 2004 as well?
Jon Smith
COINS
> Thanks,
> -jim
Message 6 of 7 (92 Views)
Re:
07-25-2003 02:21 AM in reply to: *Raj
Hi Jim -
No ill effects. We will roll-up both ADT and ACAD service packs when we
issue our own.
Everyone - keep those error reports coming in!
> Thanks,
> -jim
Message 7 of 7 (92 Views)
Re:
08-05-2003 11:20 PM in reply to: *Raj
Uh Oh!
Turns out there is a minor problem. Apparently, there is a bug that
requires that the install order of side-by-side ADT/ABS be ADT first, then
ABS. Well, installing the service pack changes the install order to ABS
first.
To fix this - go into the control panel ->Add/Remove Programs -> Autodesk
Building Systems -> Change -> Reinstall or Repair Autodesk Building Systems
2004 and continue the wizard. There is no need to reinstall any of the
applications.
My apologies...
"Peter Terwilliger [Autodesk]" wrote in
message news:C8F6F15A2E6390CDF756AFC4CE1E074C@in.WebX.maYIadrTaRb...
> Hi Jim -
> issue our own.
> > Thanks,
> > -jim
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
