I have the same.
"Error 1336. There was an error creating a temporary file that is needed to complete this install".
In my case it is when trying to make a deployment for MEP2008.
First of all I couldn´t get the installprogram to work. It delivered some fynny message and then stopped. After disconnecting from the network I tried again and got another message, "...Bla...bla DWF-viewer..." which made me unistall the previously installed viewer.
Then It started and after configuring the deployment it seemed to function, slowly, very slowly.. 0,17 - 5 % activity on the network according to taskmanager. Then, after three hours it went into loop and started all over again. Bummer! Now what?
Answer: there is a bug on the installation disc !!!
The solution to that is to copy all the files on the DVD to Harddrive and run the setup from there.
I don´t know what causes this error 1336 problem, I also have all rights everywhere (I think, unless AutoDesk wants to write outside the deployment folder, wich wouldn´t surprise me at all....).
One workaround would be to first make an ordinary deployment and then use the Modify shortcut to apply the patch.
Another workaround would be to make the deployment on local C:\, then move it to the server. After moving it, one should change the path´s in the shortcuts to make them work properly.
This has cost me some 12 hours of trial and error. Still counting.
I would very much like to know how to corect this behaviour permanently, and also like to know why AutoDesks new release installation CD:s /DVD:s never seem to work "first time" out of the box. There is always some freaking problem....
Please answer, Those who know.
