I need to make a rectangular to round transition that I can give a specific length to, similar to the Rectangular Length Concentric Duct Transition from the part catalog. Is this possible? Currently (for 2d) I just explode the regular rectangular to round transition and stretch it to a certain length. However this project is 3d and I would really perfer my system to be continuous.
Solved by mdsonline. Go to Solution.
Yes it is possible. With the content builder you can build almost any fitting that you need.
Are you looking for someone to supply you the fitting or are you looking for instructions on how to create one or modify an existing one?
You can also use the Eccentric Transition and set the 'e' & 'f' lengths to be the negative of half of the difference between the sizes (i.e. 12" to 4x6 would be 6" diff on the width & 8" diff on the height so you would enter '-3' & '-4' respectively, then you may enter any distance you'd like for 'l' (length). (see the attachment)
I didn't realize this was even an option. I've never really needed an eccentric rectangular to round transition before. Thanks so much. I bet I can make this work.
