I can create a custom property set definition for Air Terminals that will
extract and reflect the Flow amount entered in the MvParts property dialog,
and include this in a diffuser schedule.
However the default content doesn't appear to do this. Whether I tag a
diffuser with a stock diffuser tag, the flow value that is input is not the
same value that is being input in the MvParts Dialog.
I guess my question is, what is the point of inputting an amount in the
"Flow" tab of the MvParts dialog if it's not used in the diffuser schedule
or tag? Or... why don't the tags and the schedules use that value?
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
