AutoCAD MEP General
Active Contributor
lesdre
Message 1 of 7 (375 Views)
Project navigator continuously loading.
375 Views, 6 Replies
10-25-2013 12:49 PM
In my office of about 3 computers and over the course of about a year and a half we have been experiencing a problem with project navigator. When opening ACAD MEP or changing projects about 60% of the time it gets hung up and the load bar perpetually loads over and over again. If just left to run it takes 5-10 mins before loading. We contact ed autodesk and they did not find a fix for this problem and I thought autocad mep 2014 would fix the problem but it still exist. Please I need this to go away. my previous case number for this problem is CaseNo:07828454.
Leslie
ACGCadguy
Message 2 of 7 (265 Views)
Re: Project navigator continuously loading.
02-26-2014 01:18 PM in reply to: lesdre
Leslie - We've been battling with this issue for years now (even today) and Autodesk/our local reseller have never been able to resolve it.  Our IT consultants have tried many workarounds on the server, network and workstation side-of-things but nothing helped.  Like you, we've hoped year after year an update would magically fix it.
fyi - For us it all started when we migrated to Windows Server 2011/Server 2008.  Never "looped" before that.  And I've old found one other thread complaining of the same issue and to my knowledge they've never resolved it either.
If you've stumbled on a solution please let me know.
Brian
VitalyF
Message 3 of 7 (253 Views)
02-26-2014 10:42 PM in reply to: lesdre
Hi Leslie,
If you change the path to the project, the navigator at startup looking lost path.
Try manually remove all references to the old path of sheets and project properties
Or use the tool - "DTS Converter" >>
http://www.jtbworld.com/SSMPropEditor.htm
PS
Have a look here also >>
http://forums.augi.com/showthread.php?130719-Slow-Sheet-Set-Manager&p=1131275&viewfull=1#post1131275
Vitaly
ACGCadguy
Message 4 of 7 (173 Views)
04-09-2014 08:46 AM in reply to: VitalyF
Leslie - Did you ever find a solution to your slow loading issues with project navigator?  We haven't and it continues to be a thorn in our side every day.
Please let me know if you discovered a fix or workaround.
Thanks.
ACGCadguy
Message 5 of 7 (154 Views)
04-15-2014 02:00 PM in reply to: ACGCadguy
All - I stumbled upon the following official posting from Autodesk last week and it has resolved our looping issues.
http://knowledge.autodesk.com/support/autocad-mep/troubleshooting/caas/sfdcarticles/sfdcarticles/Pro...
Active Contributor
lesdre
Message 6 of 7 (102 Views)
05-15-2014 06:23 AM in reply to: ACGCadguy
Sorry it toke me so long to answer I toke off the automatic email service to my email but I still have the same issues but going to try the above.
Leslie
Active Contributor
lesdre
Message 7 of 7 (69 Views)
05-20-2014 10:34 AM in reply to: lesdre
It worked thanks.
Leslie
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
