AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Plumbing pipe catalog
4 REPLIES 4
785 Views, 4 Replies
There are only brazed, glued and threaded pipes in plumbing catalog. Is it
something wrong with my setup?
sp
4 REPLIES 4
"Slawomir Popiel" wrote in message
news:E0C7E8E2F5B558DA4989CE6739E53CC0@in.WebX.maYIadrTaRb...
> sp
Correction:
I have identical set of pipes as above, in both plumbing and piping catalog.
Somehow disppeared such pipes like flaged, welded, etc.
Anybody cares to comment on that?
sp
Hi Slawomir,
No, it is nothing wrong with your setup. The Plumbing Pipe US Imperial
catalog does only contain pipes for those connection types.
I think that the pipes that exists in both catalogs are the same; it is the
fittings that are different.
Does that answer your question?
/Bosse
news:AC83D6E1DF38B012BE37495A806A4FE6@in.WebX.maYIadrTaRb...
it
> > sp
> Correction:
catalog.
> sp
"Bo Noren [Autodesk]" wrote in message
news:E2C7332833212C435D0E0FDE48FDF48A@in.WebX.maYIadrTaRb...
> Hi Slawomir,
the
Yes and no.
Can't figure out why flanged or welded piping does not exist anymore. What
was wrong with having it?
Will pipes from ABS3 work with ABS2004? In other words, how about copying
proper folders yto ABS2004 location?
sp
Hi Slawomir,
The Pipe US Imperial (and Metric) catalogs still contain pipes and fittings
for all connection types. In BS 2004 there is an additional catalog Plumbing
Pipe US Imperial that only contain a few connection types and have other
types of fittings. You shouldn't have to copy the pipe catalogs from ABS3,
the one in ABS 2004 contain the same pipes and fittings. Which catalog are
you using? Are some connection types still missing after switching to Pipe
US Imperial catalog?
/Bosse
news:53445EF22DAACE9853E179F6B1982442@in.WebX.maYIadrTaRb...
> > Hi Slawomir,
> the
> Yes and no.
> Thanks
> sp
”Boost
