AutoCAD MEP General
*Cox, Laura
Message 1 of 2 (395 Views)
Plumbing Fixture Labels
395 Views, 1 Replies
06-26-2003 09:42 PM
I am trying to label a plumbing fixture using the fixture label from the
palette. Tha label looks correct when in the process of inserting it but
when I accept the location for the tag all that is visible are two lines.
Can anyone tell me what I'm doing wrong?
*[Autodesk], Fredrik Andersson
Message 2 of 2 (395 Views)
Re: Plumbing Fixture Labels
09-02-2003 11:27 PM in reply to: *Cox, Laura
Hi Laura
What you see is a underlined hyphen...
This happens because default "Name" of the tag is "-".
Please see help file > Building Systems 2004 Help > Building Systems
Tutorial > Plumbing Tutorial >
Lesson 9 - Exercise 1: Adding Schedule Tags to Fixture..
The key to success is to add a name for Item during the process of adding
the tag.
If you would like "P - 1" (or anything else) as default setting when using
the Fixture Tag, try this:
1. Start Design Center and select the Custom tab
2. Browse to Imperial > Documentation > Schedule Tags > Plumbing Tags
3. Right click "Fixture Tag 4" and select Open from Pop up menu
4. On command line type "AecpropertysetDefine" and then press enter
5. Right click "MvParts-FixtureUnits-Objects" and select Edit.
6. On definition tab, select Item. Change default value from "-" to "P-1"
(or anything else)
7. Please make a backup of the drawing file before saving.
Regards
Fredrik Andersson
"Laura Cox" wrote in message
news:C4C8A47C9774E9583E0D6761F5CA5348@in.WebX.maYIadrTaRb...
> Thanks
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
