One method is going into Format>Drawing Setup, go to the display tab and
then turn off the connectors for the line type you are using. Thing is, the
fittings don't stand out as clearly doing that. What we did, was change the
connector type so that we would get the proper results. Guess it all
depends what you are tying to do.
Mike
"jesseu" wrote in message
news:15779610.1083169900938.JavaMail.jive@jiveforum1.autodesk.com...
> How do you change or turn off the X's when 2line display for piping? the
boss does not like this display.
> Jesse Urquidi
> P2S Engineering
