AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Pipe & Duct Elevation Settings
2 REPLIES 2
222 Views, 2 Replies
For some reason my duct and pipe insertions are going to the negative value. It worked fine until lately. If I try to insert a pipe or duct at 10' it is being installed at -10', If I set it to insert at -10' it will go in at 10'. is their a setting that makes this work in reverse?
2 REPLIES 2
Is there any way your UCS has been flipped 180 degrees around the X or Y axis? "P.Temporale" wrote in message news:4180fd25$1_1@newsprd01... > For some reason my duct and pipe insertions are going to the negative > value. > It worked fine until lately. If I try to insert a pipe or duct at 10' it > is > being installed at -10', If I set it to insert at -10' it will go in at > 10'. is their a setting that makes this work in reverse? > >
BHashman
type plan at the command prompt and select world. To set the view back to world view. Does that help?
”Boost
