AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
PIPE COMES IN SINGLE LINE IN NAVIS
5 REPLIES 5
mjmpe
2595 Views, 5 Replies
Why is it that some of my pipe is coming in single line in Navisworks? when all the other trades are fine, What am I doing wrong? or what do I need to do to fix this?
thanks
5 REPLIES 5
Keith.Brown
in reply to: mjmpe
The problem is actually with Navisworks.  You need to have your Navisworks operator go into their options and under File Readers->DWG/DXF uncheck the box that says Use ADT standard Configuration.  What that does is force your drawing to display in the standard display configuration instead of the configuration that you drew the pipe in.
A secondary option for you is to modify the Standard Display Configuration to display pipe in 2 line.  I prefer changing it in Navisworks myself.
Keith.Brown
in reply to: Keith.Brown
Just checking in and seeing if this fixed your issue?
gregE4BEG
It did not work for me. Still showing conduit as single line.
ekolto
This worked for me, thanks!
mctim
Worked for me. You can't use the nwc that was created , but when I loaded the dwg it worked fine.
Thank you
”Boost
