tag the PDF through the paper space window and "bring to the front" or "on top" option in the Display order tab of the right click modify tool window. Also double check to make sure the PDF is not on a non-plot layer.
Layer zero can act a little crazy sometimes especially when used in conjunction with Defpoints. It is best to try and avoid layer 0 and Defpoints as much as possible. The layer defpoints is up near the top of admitted mistakes by Autodesk.
I would try moving the pdf from layer 0 and place it on another layer.
make sure the pdf is on the layer so you can c# print pdf document normally. use an pdf processor to help you when you want to convert or resize.
Hi, dtimage.
Thanks for your tips. I also have some tutorials about how to print PDF files. I also do as it tells the users. So far so good.
Best regards,
Arron
