AutoCAD MEP General
Distinguished Contributor
Message 1 of 4 (165 Views)
Mvpart selection default folder settings?
165 Views, 3 Replies
07-10-2003 11:13 PM
Everytime I try and add a new Mvpart to my drawing the selection defaults to an air curtain. I then have to traverse back through all the folders to get down to a VAV folder. I add a VAV box to my drawing. I select the add Mvpart again, the selection is back again to the air curtain selection. I again have to traverse back through all the menus back down to the VAV boxes. Doing this time and time again gets to be a PAIN! Is there a way to stop the Mvpart catalog from defaulting to air curtains and revert back to the last part added folder??
Valued Contributor
Message 2 of 4 (165 Views)
Re: Mvpart selection default folder settings?
07-10-2003 11:35 PM in reply to: jmcfaddn
good question... I've had the same problem.
*[Autodesk], Lars-Ake Johansson
Message 3 of 4 (165 Views)
Hi Jody,
The MvPart Add dialog should by default open up on
the last part used exepti in one case; If you choose 'Add Mechanical Equipment'
from the tool palette.
You can change tis behaviuer if you want by
changing the command on that tool.
1. Right click on the icon and choose
Properties...
2. Click on the command text
3. Change the command to ^C^C(command "_MvPartAdd"
"t" "All")
Hope this helps
Lars-Ake Johansson
Autodesk BSD QA
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Everytime
folder??
*[Autodesk], jason martin
Message 4 of 4 (165 Views)
Re:
07-11-2003 12:31 AM in reply to: jmcfaddn
Or you can just copy (or use) the add equipment tool from the MEP palette
Add Mechanical equipment puts you back at the top of the mechanical list.
Add Terminal puts you back at the top of the terminal list
Add Fan puts you back at the top of the fan list
Add equipment puts you back where you were.
hth
jason
"Lars-Ake Johansson [Autodesk]" wrote in
message news:B5FE0DDE9028599B1ED03AFDBDCCCBA9@in.WebX.maYIadrTaRb...
> Hi Jody,
> The MvPart Add dialog should by default open up on the last part used
exepti in one case; If you choose 'Add Mechanical Equipment' from the tool
palette.
> You can change tis behaviuer if you want by changing the command on that
tool.
> 1. Right click on the icon and choose Properties...
> 3. Change the command to ^C^C(command "_MvPartAdd" "t" "All")
> Hope this helps
> Lars-Ake Johansson
> Autodesk BSD QA
> "jmcfaddn" wrote in message
news:f176a37.-1@WebX.maYIadrTaRb...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
