Hey for some reason my pen table do not show up in the plot style table pull down menu in the plot dialogue box when plotting from a construct or view. I have the search paths set up in options and my pen table show up in the views and when I just open up random files. Any ideas?
Solved by mancell7462. Go to Solution.
Solved by Shawn_Niles. Go to Solution.
Are you seeing anything at all in the list? AutoCAD will show only CTB or STB files, but not both at once. If you are just not seeing the type you want, type in CONVERTPSTYLES at the command line and this will allow you to see the other type of file. Does this help?
