AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Mechanical Pipe Risers
1 REPLY 1
357 Views, 1 Reply
When I draw a pipe and end it with a turn up as a riser the single line drawing shows it as a turn down symbol if I remove any straight pipe connected to the elbow that turns up it shows as a riser symbol. Is there a fix to this besides erasing any vertical pipes on my risers?
1 REPLY 1
Have you tried to change the flow direction? Select the riser pipe, right click mouse, select set flow, then select reverse. See if that changes your riser symbol.
Let me know.
Jmcfaddn
”Boost
