AutoCAD MEP General
Message 1 of 2 (307 Views)
MEP Light Switches
307 Views, 1 Replies
09-13-2012 01:30 PM
I noticed in the tool palette that MEP only offers single pole and 3-way switches. I'm looking to set a 2g single pole switch
and MEP doesn't offer one. I tried taking two single pole switches and placing them side by side. In the 3D view it shows the switches sitting roughly 2' apart. When I take the switches in the model and place them side by side then in plan view the two switch symbols are sitting on top of one another and no longer looks like a 2g single pole switch. Is there anyway to edit the switches and or create a new one that still holds the wire connection function?
Thanks!
Active Member
Message 2 of 2 (287 Views)
Re: MEP Light Switches
09-17-2012 05:20 AM in reply to: dfaircloth927
coy the style from a single pole switch. but under the connectors tab, add another connector.  Be sure to change the location or the connectors will be on top of each other.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
