AutoCAD MEP General
Member
saidriad71
Message 1 of 2 (401 Views)
MEP 2013: Duct, Add Property Sets
401 Views, 1 Replies
09-20-2012 12:37 PM
Hello all,
When I draw duct work, then select any duct I have drawn, right click and select properties, if I then go to the "Extended Data" tab, I will not see the property set definitions "DuctObject".
The only way I can have it display on the extended data tab, is if I go to the bottom left hand corner of my tool palette, to "Add Property Sets", and then press "ok", I don't have to select "DuctObject" before I press ok because they are already selected.
Is there a setting that will make the "DuctObject" display on the extended data tab of the tool palette automatically?
Please, realy need help!
Keith.Brown
Message 2 of 2 (399 Views)
Re: MEP 2013: Duct, Add Property Sets
09-20-2012 01:20 PM in reply to: saidriad71
Property sets are not added automatically to objects as you draw them.  So when you go to the extended data tab you will not see any property sets until they are added which is the exact process that you described.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
