AutoCAD MEP General
Active Member
dallasn
Message 1 of 4 (80 Views)
Lining on Eccentric Transitions
80 Views, 3 Replies
03-11-2003 06:07 AM
I have found that when applying lining to the eccentric transition duct fittings that the display in plan view goes a bit wierd (it offsets to one side), but looks correct in model view. This seems to occur only with this kind of fitting (so far).
Has anyone else had the same experience or found a solution?
Also, has anyone found a way to make a round to square eccentric transition?
Dallas
*[Autodesk], jason martin
Message 2 of 4 (80 Views)
03-11-2003 09:02 PM in reply to: dallasn
Hi Dallas -
Yea, that doesn't work very well. I've logged a defect against this problem,
and I'll let you know if anyone comes up with a work around for it.
jason
"dallasn" wrote in message
news:f14d280.-1@WebX.maYIadrTaRb...
transition?
> Thanks,
> Dallas
*Ward, Rob
Message 3 of 4 (80 Views)
03-11-2003 09:16 PM in reply to: dallasn
I have had the same problem and can't seem to find
a solutions for it.  I think that it might have something to do
with the plan view block of the fitting.
-Rob
I
fitting (so far).
transition?
Dallas
Active Member
dallasn
Message 4 of 4 (80 Views)
Re: Lining on Eccentric Transitions
03-12-2003 02:50 AM in reply to: dallasn
Hi Jason,
If you could post the procedure for setting multiple colours for MVParts that would be greatly appreciated!!
Dallas
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
