AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Lining on Eccentric Transitions
3 REPLIES 3
222 Views, 3 Replies
I have found that when applying lining to the eccentric transition duct fittings that the display in plan view goes a bit wierd (it offsets to one side), but looks correct in model view. This seems to occur only with this kind of fitting (so far).
Has anyone else had the same experience or found a solution?
Also, has anyone found a way to make a round to square eccentric transition?
Dallas
3 REPLIES 3
Hi Dallas -
Yea, that doesn't work very well. I've logged a defect against this problem,
and I'll let you know if anyone comes up with a work around for it.
jason
"dallasn" wrote in message
news:f14d280.-1@WebX.maYIadrTaRb...
transition?
> Thanks,
> Dallas
I have had the same problem and can't seem to find
a solutions for it.  I think that it might have something to do
with the plan view block of the fitting.
-Rob
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
fitting (so far).
transition?
Dallas
Hi Jason,
If you could post the procedure for setting multiple colours for MVParts that would be greatly appreciated!!
Dallas
”Boost
