AutoCAD MEP General
Distinguished Contributor ken
ken
Message 1 of 3 (542 Views)
Lines merge doesn't work in 2014
542 Views, 2 Replies
10-08-2013 12:05 PM
Ok we have just noticed that the Lines Merge option of any printer including the one that came with AutoCAD MEP 2014 does not work.  We went back to our AutoCAD MEP 2013 and all is well.
We thought well if its a driver issue the DWG to PDF driver from AutoCAD should work right? Nope it does not.
What happened in 2014?
Just wondering,
Ken
Product Support
Shawn_Niles
Message 2 of 3 (509 Views)
Re: Lines merge doesn't work in 2014
10-11-2013 08:49 AM in reply to: ken
This is a known issue that has been present for several releases. The current workaround if you need to use the Lines Merge feature is to plot to DWF instead, and print the file using Design Review. The problem only shows itself with PDF files.
Shawn Niles
Hammer.john.j
Message 3 of 3 (419 Views)
11-05-2013 11:50 AM in reply to: Shawn_Niles
linesmerge works with civil 3d 2012 latest service pack using dwgtopdf.pc3 or whatever it's called.
if all else fails, create plot files and use CADZATIONS acroplot pro to convert plt to pdf.. because their printer driver ACTUALLY WORKS, and it's well known that autodesk cough cough took a look at cadzations to make their own so says the rumor.
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
