AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Labeling 2d sections without exploding
1 REPLY 1
jgerst
354 Views, 1 Reply
I'm looking for a code way to get an object layer out of a 2d section without exploding it
need to add to a lisp file that adds text to a line or leader with text
Looks like it might be deep in the Object data someplace further then my code exp reaches.
using MEP14  AEC_2D_SECTION
1 REPLY 1
marco.defina
in reply to: jgerst
Try with the section edit...
Select the 2D section and use this command: 2dSectionResultEdit
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
”Boost
