Excellent, Mike. That did the trick. You're the hero of the day. I'm curious
how you found this out.
Emmanuel
"Mike Hutchinson" wrote in message
news:3E78D505.790AD805@bbsae.com...
> It is my understanding that Label Text height gets is controlled by
> the text style.
> If the text style is set to 0, then control passes to what is set on the
scale
> tab of the Drawing Setup dialog box.
> In this case the height of the dwg is determined by useing Arch scale and
> Annotation Plot Size.
> In other words... arch scale of 1/8"=1'-0 is 90
> and Annotation Plot Size is 3/32"
> then the text height = 96" x 3/32"
> If on the other hand the text style is set to 3 for instance then you
label
> text height will be just that.
> Emmanuel Garcia wrote:
> > How is the label text height set? I looked under properties and under
style
> > definition to no avail. i had hoped the labels were mview blocks that
could
> > be manipulated using the Display System, but they're AECB_LABEL_CURVE
> > entities. What's the secret?
> > Regards,
> > Emmanuel
