Are you referring to the ones in design center? If so, copy them from BS3
or from a previous drawing you used them and put them in the appropriate
ABS4 design center location. The default location in ABS2004 is "\documents
and settings\all users\application data\autodesk\autodesk building
systems\2004\r16.0\enu\aec content\imperial\documentation\leaders\"
"scott_"
wrote in message
news:193EB8CEDACBB01FA1E0B56487475F57@in.WebX.maYIadrTaRb...
> These loop leaders were in Building Systems 3. Now they are gone. Why did
> autodesk get ride of them?
> Scott
> "Andrew" wrote in message
> news:A40BADC02B72AB84294128CB8111C5D9@in.WebX.maYIadrTaRb...
> > You can make your own. Use the "User Arrow" under arrowheads and
select
> > your custom loop block. Keep in mind the block must reside in your
> drawing.
> > I can post the ones I made to customer files if you want them. I have
> some
> > for 8" and 12" pipe spacing but they can be easily modified to use what
> ever
> > spacing you use.
> > "Rob Ward" wrote in message
> > news:DCB77BE80BF8ED78359C76DB544A798F@in.WebX.maYIadrTaRb...
> > > I would also like to know where these went to. I haven't seen them
> since
> > > S8. We use them quite often for tagging single line piping and I have
> had
> > > to resort to using the *none* leader and attaching an arc to loop
around
> > the
> > > pipe. This was a common thing in S8 where did they go?
> > > regards,
> > > ~Rob
> > > "scott_" wrote in message
> > > news:f1933e1.-1@WebX.maYIadrTaRb...
> > > > Where are they loop leaders located in BS4?
> > > > Scott
