AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
LOOP LEADERS
5 REPLIES 5
372 Views, 5 Replies
LOOP LEADERS
Where are they loop leaders located in BS4?
Scott
5 REPLIES 5
I would also like to know where these went to. I haven't seen them since
S8. We use them quite often for tagging single line piping and I have had
to resort to using the *none* leader and attaching an arc to loop around the
pipe. This was a common thing in S8 where did they go?
regards,
~Rob
"scott_" wrote in message
news:f1933e1.-1@WebX.maYIadrTaRb...
> Scott
You can make your own. Use the "User Arrow" under arrowheads and select
your custom loop block. Keep in mind the block must reside in your drawing.
I can post the ones I made to customer files if you want them. I have some
for 8" and 12" pipe spacing but they can be easily modified to use what ever
spacing you use.
"Rob Ward" wrote in message
news:DCB77BE80BF8ED78359C76DB544A798F@in.WebX.maYIadrTaRb...
the
> regards,
> ~Rob
> > Scott
These loop leaders were in Building Systems 3. Now they are gone. Why did
autodesk get ride of them?
Scott
"Andrew" wrote in message
news:A40BADC02B72AB84294128CB8111C5D9@in.WebX.maYIadrTaRb...
drawing.
some
ever
> spacing you use.
since
had
> the
> > regards,
> > ~Rob
> > > Scott
Are you referring to the ones in design center? If so, copy them from BS3
or from a previous drawing you used them and put them in the appropriate
ABS4 design center location. The default location in ABS2004 is "\documents
and settings\all users\application data\autodesk\autodesk building
systems\2004\r16.0\enu\aec content\imperial\documentation\leaders\"
news:193EB8CEDACBB01FA1E0B56487475F57@in.WebX.maYIadrTaRb...
> Scott
select
> drawing.
> some
> ever
> > spacing you use.
> since
> had
around
> > the
> > > regards,
> > > ~Rob
> > > > Scott
Problem is I am working for a new company. They place I came from we used
BS3 before we got BS4.
Scott
news:B3B6140B20178E5D84C6CB8BE25DE8EE@in.WebX.maYIadrTaRb...
"\documents
did
> > Scott
> select
> > drawing.
> > some
what
> > ever
> > > spacing you use.
> > since
have
> > had
> around
> > > the
> > > > regards,
> > > > ~Rob
> > > > > Scott
”Boost
