AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
KIP 3100 Plotting issue
1 REPLY 1
robarge311
577 Views, 1 Reply
I am currently using Autocad MEP 2011 connected to a kip3100 plotter. Recently the plots have been off center (cutting the tops and bottoms off plots), although their print previews show otherwise. Also, there seems to be a consistant and similar issue with plotting dwgs to pdfs. I have unistalled and reinstalled autocad as well as tried to calibrate the plotter. Nothing out of autocad seems to be working. Does anyone know how to resolve this issue, or is it an issue with the plotter?
1 REPLY 1
chadclark
in reply to: robarge311
We use a KIP 3100.  Do you have the AutoCAD print driver installed?  Also do you have extents, display, limits, or window selected under plot area?  Also make sure you have center plot selected under Plot Offset.
”Boost
