AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Install Error: SP1 could not be applied... Could not be found.
0 REPLIES 0
Message 1 of 1
mdhutchinson
553 Views, 0 Replies
32 bit Windows XP box...
I got an Installation Error. "The service pack could not be installed because the expected Autodesk product could not be located on you computer. Make sure that you are using the correct service pack for the product."
I double checked that the correct service pack was used.... I also did a re-install of AutoCAD MEP 2013 in maintenance mode.
See attached image.
0 REPLIES 0
”Boost
