AutoCAD MEP General
Valued Mentor
Message 1 of 3 (398 Views)
Info explaining pitfalls having to do with BACKWARD Compatibility
398 Views, 2 Replies
09-28-2012 05:33 AM
Could someone point me to a doc that does a good job on explaining backward compatibility in MEP...  2013 saving back to past releases?
Product Support
Message 2 of 3 (368 Views)
Re: Info explaining pitfalls having to do with BACKWARD Compatibility
10-01-2012 01:39 PM in reply to: mdhutchinson
We do not have a document, but have two TS’s.
From 2013 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18801721&linkID=9240617  (Applies to Core AutoCAD, but not entirely to AEC verticals.  Ie. Cannot save backwards across file format.)
From 2010 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13117479&linkID=9240657
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Message 3 of 3 (349 Views)
10-03-2012 07:30 AM in reply to: Joshua.Benoist
Mike,
Did the above links help?  That's all the documentation we have other than the myriad forum posts on this topic.
Joshua
Joshua Benoist, PE
Product Support
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
