AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Importing CADDuct and CADPipe Models in Revit via AutoCAD MEP
1 REPLY 1
1687 Views, 1 Reply
I am trying to import CADDuct and CADPipe Models in Revit. I do not have license for either CADDuct or CADPipe.  So the way I am doing this is by opening the DWG files in AutoCAD MEP and exporting them as IFC's and at last importing (opening) IFC file in Revit.
By this method most of the geometry comes through but there is no intelligence to the model. The duct in Revit is just a Generic Model and there are no properties associated with the duct. I have tried other ways of bringing the CAD data into Revit but in all the cases I have been able to get the geometry but no associated data comes along.
I really need help in resolving this issue.
Thank you.
Kushagra
1 REPLY 1
Nicholas.Hyland
Hi Kushagram,
The only way to access the CADmep properties generically (without purchasing the application) would be to use the MapsComW which is installed with the Fabrication CADmep 2013 object enabler.
You may then be able to get the properties to appear in the IFC output (for validation it may be an idea to contact the AutoCAD MEP team to see if they do extract the CADmep properties from the enabler).
If these properties do not appear in Revit (but do appear in other IFC viewers) then that issue would be best raised with the Revit support team. I would suggest submitting through the Contact Us > Feedback > Products (product features and improvements you would like to see) link at the top of this page.
I hope this helps.
Nick
Nicholas Hyland
”Boost
