AutoCAD MEP General
Keith.Brown
Message 1 of 5 (380 Views)
IFC Export of MvParts
380 Views, 4 Replies
05-29-2012 01:01 PM
Hi.
I am trying to export an AutoCAD Mep model to IFC and I am not having alot of luck exporting the information that I want.  Currently my drawing is very simple and only containes a few spaces and 2 VAV boxes.  The two VAV boxes have their IFCTC columns in content builder set to IfcFanType.NOTDEFINED.  The subtype of the part is set to SINGLE DUCT VAV.  When I export the file, I get this line describing the VAV box.
#1765=IFCFANTYPE('0RFsBvPhT8hgK6ItbtVPAW',#33,'Single Duct VAV','','',(#1764),$,'','Single Duct VAV',.NOTDEFINED.);
The output line is described by the following:
Attribute                                              Type                                                    Defined By
GlobalIdIfcGloballyUniqueId (STRING)IfcRoot
OwnerHistoryIfcOwnerHistory (ENTITY)IfcRoot
NameIfcLabel (STRING)IfcRoot
DescriptionIfcText (STRING)IfcRoot
ApplicableOccurrenceIfcLabel (STRING)IfcTypeObject
HasPropertySetsSET OF IfcPropertySetDefinition (ENTITY)IfcTypeObject
RepresentationMapsLIST OF IfcRepresentationMap (ENTITY)IfcTypeProduct
TagIfcLabel (STRING)IfcTypeProduct
ElementTypeIfcLabel (STRING)IfcElementType
PredefinedTypeIfcFanTypeEnum (ENUM)IfcFanType
So Both the name and the ElementType is being set to "SINGLE DUCT VAV'.  This is not what I want.  I want the Name to be the partsize name.  So I did a little digging and got to this page in the help file.
http://exchange.autodesk.com/autocadmep/enu/online-help/search#WS1a9193826455f5ff29a9843712b1addac1f...
I believe that this page is telling me that if I add the following property set: IFCObjectAttributes{IFCFanType] found in the IFC Property Sets location that I can override these values.  I have attached the property set, filled in the values that I want, but still get the original values.
I am at a loss at what to try next.  It is clear that the IFC exporter is not working correctly.  Why would it take the name of the part and insert the part subtype into it.  What if i have 100 of the same type of part in a single drawing.  There is no way to distinguish one from another.
Has anyone tried something like this before and came across this issue?  Any help on the matter would be appreciated.
Keith
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
Keith.Brown
Message 2 of 5 (375 Views)
Re: IFC Export of MvParts
05-29-2012 02:49 PM in reply to: Keith.Brown
**** UPDATE ****
I have found that the method talked about in my previous post works just fine for architectural objects. i.e. (spaces).  I can attach the appropriate property set to a space and override the name and description.  But still no luck for MEP.
Why can't they make them work the same?
Product Support
Message 3 of 5 (356 Views)
06-04-2012 01:49 PM in reply to: Keith.Brown
I do not know the answer and have emailed some guys that may be able to help.
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Keith.Brown
Message 4 of 5 (354 Views)
06-04-2012 01:56 PM in reply to: Keith.Brown
Thank you Joshua.
Product Support
Message 5 of 5 (307 Views)
06-14-2012 02:16 PM in reply to: Keith.Brown
Our developers have confirmed as well, that MEP objects do not behave the same as the Architectural.  They are now aware of this behavior and are researching how to address it.
Joshua
Joshua Benoist, PE
Product Support
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
