AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How to tell if you've purged all occurences of a part?
5 REPLIES 5
jmcfaddn
309 Views, 5 Replies
How can you tell if you've purged all occurences of a particular part? Jason Martin with Autodesk states that a part cannot be replaced until it has been completely purged from the drawing. Well I've done that, unless there is another one lingering around the drawing some place, and I still cannot get my modified Mvpart to come in properly.
5 REPLIES 5
in reply to: jmcfaddn
Use quickselect to select all the instances of the part by sizename
jason
"jmcfaddn" wrote in message
news:f17a82f.-1@WebX.maYIadrTaRb...
jmcfaddn
That'd be good if I could find the fricken thing. Help says go to the TOOLS pulldown. I don't have one???
It's on the properties palette. It looks like a funnel with a lightening
bolt, or type qselect.
jason
news:f17a82f.1@WebX.maYIadrTaRb...
Type qselect at the command line....
That'd
I don't have one???
jmcfaddn
Using the filter command before in ACAD14 I could select an object. It would then add the properties to the filter window and you could delete the properties from the filter you did not want to use. For instance Name,color,location,linetype, etc. This one does not appear to do that. How can you preselect an object to set the filtering properties without having to type them all in?
”Boost
