AutoCAD MEP General
*Abernethy, Mike
Message 1 of 3 (375 Views)
How to set the rotation of duct size labels?
375 Views, 2 Replies
06-30-2003 05:02 AM
The duct size labels are inserted where you have to read them from the left
side of the sheet. Is there anywhere to set them so they can be read from
the right side?
Distinguished Contributor
Message 2 of 3 (375 Views)
Re: How to set the rotation of duct size labels?
06-30-2003 05:05 AM in reply to: *Abernethy, Mike
I have that same question.
*[Autodesk], Bo Noren
Message 3 of 3 (375 Views)
07-01-2003 12:31 AM in reply to: *Abernethy, Mike
Hi Mike,
Today the labels are rotated different depending on from which end you start
drawing the duct when creating a duct in the Y-direction. I assume that you
always want the label inserted to be read from the right side of the sheet
and not depending on which end you start drawing the duct from (if the duct
is in the Y-direction).
The only setting that exists today is to place all labels "horizontal". It
is defined on the label style. It is possible to rotate multiple labels
though. Select the labels you want to rotate, right click and select Rotate
node. Chose to edit All nodes, select Ucs and angle 90. Selecting all
"wrong" labels can be quite hard and I haven't found any good solutions for
selecting them easily:-(
/Bosse
"Mike Abernethy" wrote in message
news:59D26E6D3B7C076CF31B5C6021BBDED9@in.WebX.maYIadrTaRb...
left
> the right side?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
