AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How to draw J-hooks?
3 REPLIES 3
tungkims
5407 Views, 3 Replies
Hi everyone.
I am newbie and am trying to draw J-hook for Telecommunication Cables.
Anyone knows how to do it?
3 REPLIES 3
smbrennan
in reply to: tungkims
I'd suggest creating a basic 3D model and working with that in 3D, but then again I tend to use new technology in an old-fashioned way.
Assuming your J-Hooks are bent sheet metal like they appear in the image, follow these steps:
  • Create the profile of your J-hook (a 'J' in this case). Use polylines and make sure they're close.
  • Extrude the closed polyline the depth of the hook.
  • In a 3D view, create a circle for your 3/8" rod, place that where it's located on the hook. Extrude that to the deck/structure it's attaching to.
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
tungkims
in reply to: smbrennan
Thank you for your advice. I will try to do it and let you know soon.
Keith.Brown
You have a couple of options available to you.  I tend to create all of my hangers as mvparts and that is certainly an option.  Just add a pipe connector to where the threaded rod would normally attach.  You can also create the j-hook as a structural member.  You can add the 3D block to the end of a round structural member, in this case the size of the threaded portion of the hook.  You can then add the structural member and the j-hook will be attached to one end of the member.  This will allow you to stretch the threaded portion of the hook to any length you like.
”Boost
