I believe the one you are looking for is "Device Keynote -
Hexagon"...the 1 in L1 can be turned off inside the property set, so you
are left with the letter only.
The ID is still there, but our schedules do not default to it. Instead,
the tag lettering is called the "Mark" which we are now using
consistently between disciplines and their tags.
If you prefer the ID, it is easily tweaked in the equipment schedules.
Hope this helps.
Joshua Benoist, PE (Autodesk)
kenaslan wrote:
> Thank you but I have tried using the "Lighting Device-Hexagon" the one with L on top and 1 on bottom. I cannot get it to insert the Light ID. Nor can get the 1 to go away. All I want is a letter inside of a hexagon. I am entering the ID in the ID space in Design Data .Design tab, Advanced,Design Data, ID. I must be doing something wrong. I have only been using ABS now for a couple of months as our company is thinking of going down that road. It mostly is a time saver, however Autodesk has not made this program intuitive.
> Thanks
> Ken
> ABS test dummy 🙂
