AutoCAD MEP General
New Member
Message 1 of 5 (138 Views)
HVAC Duct Fitting problem
138 Views, 4 Replies
06-09-2003 06:14 AM
When drawing HVAC ductwork I want to use mitered elbows for all 90 deg turns and radiused elbows for non-90 turns. First there is no way that I can tell to do this. Second I typically draw with the mitered elbows and then use duct fitting modify to change the non-90's back to radiused. This worked fine in BS-3. In BS-2004 it will change one elbow to radiused but when I go to change the next one it will convert the first one back to a mitered elbow. This is a bog problem for me. Any solutions to either problem?
*[Autodesk], Bo Noren
Message 2 of 5 (138 Views)
Re: HVAC Duct Fitting problem
06-09-2003 09:51 PM in reply to: cgolden
It is not possible to define different part types
for different elbow angles in preferences as you want. The problem you have
found with modifying the elbows seems to be an error when modifying two fittings
in the same duct run. I have logged it as a defect (DID502815). I haven't found
any work around for that problem yet:-(
The only tip I can give you is to switch between
mitered and radius elbow when you are laying out duct work. Click on the arrow
next to the Preference button in the Add Dashboard to quickly switch
between different parts. This might not be an acceptable solution for you but it
is the only one I can think of right now.
/Bosse
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
When
*[Autodesk], Kevin Mak
Message 3 of 5 (138 Views)
Re:
06-10-2003 03:11 AM in reply to: cgolden
cgolden,
The problem is that when modifying the subtype of a
fitting, it looks into the preferences and modify the connected fittings
according to preferences. There is a work-around for
this:
1. Set your preferences for elbow to "NONE" in
duct preference
2. When modify your non-90 degree mitered elbow to
any other subtype (smooth radius), you will get a prompt "No Default Part has
been specified for Use in this Situation."
3. Click "Ignore and Continue" to ignore the
subsequent modifications on the two sides connecting the elbow (So
you have to click "Ignore and Continue" twice)
Then your elbow should be modified to smooth
radius without changing any other elbows in the connected run.
Hope this helps,
Kevin Mak
[Autodesk, Inc.]
fittings in the same duct run. I have logged it as a defect (DID502815). I
haven't found any work around for that problem yet:-(
it is the only one I can think of right now.
/Bosse
When
problem?
New Member
Message 4 of 5 (138 Views)
Re:
06-11-2003 11:54 AM in reply to: cgolden
Bo & Kevin,
Thank you both for the help. That is a pretty decent work around. I assume that an update to correct that will amek its way down the pipe sometime in the near future but for now I can get by. Also, just as a suggestion for a future "feature" the ability to specify different elbow fittings for 90 degree turns and non-90 would be very helpful. There are quite a few people out here that use mitered elbows for 90 degree turns but spec radiused elbows for non-90 degree turns.
Thanks again for the help.
Chris
Message 5 of 5 (138 Views)
Re:
06-11-2003 10:07 PM in reply to: cgolden
Chris,
Thank you for your suggestion. It's very
important for us to know how real-world users want our product to work. We will
discuss this in the future.
Kevin
[Autodesk]
Bo
& Kevin,
degree turns.
Chris
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
