AutoCAD MEP General
Active Contributor
sixpack_cuda
Message 1 of 5 (3,531 Views)
GIZMO Off
3531 Views, 4 Replies
01-25-2013 06:54 AM
Is there any way to permanently and globally turn off the Gizmo? I'm constantly setting DEFAULTGIZMO to 3 in my drawings, but it resets to 1 after reopening the drawing.
I'm using MEP 2013. Any help is appreciated!
Product Support
Joshua.Benoist
Message 2 of 5 (3,482 Views)
Re: GIZMO Off
01-30-2013 12:18 PM in reply to: sixpack_cuda
See http://screencast.com/t/DJPct3lphz
Behavior cannot be changed.
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Active Contributor
sixpack_cuda
Message 3 of 5 (3,480 Views)
Re: GIZMO Off
01-30-2013 12:22 PM in reply to: sixpack_cuda
That is, disappointing.  But thanks for your reply.
jvernice
Message 4 of 5 (3,452 Views)
Re: GIZMO Off
02-02-2013 06:58 AM in reply to: sixpack_cuda
Just add the following line to your acaddoc.lsp file:
(setvar "DEFAULTGIZMO" 3)
If you haven’t already created an acaddoc.lsp file, use notepad to save one in C:\Users\<loginname>\AppData\Roaming\Autodesk\MEP 2012\enu\Support.
JMV
Active Contributor
sixpack_cuda
Message 5 of 5 (3,426 Views)
Re: GIZMO Off
02-04-2013 06:56 AM in reply to: jvernice
That worked perfectly, thank you!
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
