AutoCAD MEP General
Active Contributor
Message 1 of 3 (306 Views)
Fixation units - flow diagram
306 Views, 2 Replies
10-05-2012 02:29 AM
is there any possiblity and if yes how to change Fixation unit - flow diagram for plumbing sizing?
I would like to define the different diagram than the standard but i just cannot find it.
any support would be excelent and i would be gratefull if somebody could support in this matter.
Thank you
Active Contributor
Message 2 of 3 (304 Views)
Re: Fixation units - flow diagram
10-05-2012 02:32 AM in reply to: Milos84
Sorry - Fixture unit diagramm
*Expert Elite*
Keith.Brown
Message 3 of 3 (295 Views)
10-05-2012 09:33 AM in reply to: Milos84
Go into the style manager found on the manage tab of the ribbon.  Once there expand Plumbing Objects and then Fixture Unit Table Definitions.  Right Click on the standard table and copy/paste a new definition.  Rename to a name consistant with your standards and then modify your new table.  Also under Plumbing Objects you will find the Sanitary and Supply Sizing Tables that will also need to be duplicated and modified to your standards.
Hope this helps.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
