AutoCAD MEP General
Valued Contributor
Message 1 of 10 (1,005 Views)
Fillet command not working
1005 Views, 9 Replies
08-09-2006 09:34 AM
Although this may not be a BS problem, I'm posting here because I happen to be using BS2006 when I run into the problem. When I try to use the command alias "F" for fillet, I get a "Unknown command" message at the command prompt. But if I type in the full command "Fillet", it works fine. I checked the Autocad Alias Editor under Express Tools and it shows the alias "F" assigned to the "Fillet" command. I tried removing it, and then adding it back in, and saving the pgp file, but I still get "Unknown command" at the command prompt when I try to use "F" for fillet. What am I missing here?
Thanks in advance.
*AP
Message 2 of 10 (1,005 Views)
Re: Fillet command not working
08-09-2006 10:29 AM in reply to: montero1
Open the acap.pgp directly from CAD Manager | Customize | Edit program
parameters (acad.pgp). Is the F alias present?
Valued Contributor
Message 3 of 10 (1,005 Views)
08-09-2006 11:03 AM in reply to: montero1
I'm sorry, how do access CAD Manager? Is it in one of the pulldown menus?
*AP
Message 4 of 10 (1,005 Views)
08-09-2006 12:00 PM in reply to: montero1
Yes. It is not loaded by default. Use menuload and look for the
ABSCadManager.cui.
Distinguished Contributor
Message 5 of 10 (1,005 Views)
05-14-2007 01:02 PM in reply to: montero1
I am curious, i can't call the command fillet or _fillet from the lisp routines I have but I can call _fillet from the command line?
Any reason other than the pgp file this can occur?
Message 6 of 10 (1,005 Views)
05-14-2007 01:14 PM in reply to: montero1
What is even more perplexing is everytime I try to run a lisp routine calling the fillet command it blows out the pgp file altogether and I have to run a reinit?
*R. Robert Bell
Message 7 of 10 (1,005 Views)
05-14-2007 01:24 PM in reply to: montero1
Undefine was run on Fillet. To execute the internal command you need to use:
(command "._Fillet" ...)
R. Robert Bell
wrote in message news:5585585@discussion.autodesk.com...
*R. Robert Bell
Message 8 of 10 (1,005 Views)
Once again, undefine was applied to the command.
R. Robert Bell
wrote in message news:5585628@discussion.autodesk.com...
to run a reinit?
Message 9 of 10 (1,005 Views)
05-14-2007 01:44 PM in reply to: montero1
Thanks Robert =)
Message 10 of 10 (1,005 Views)
05-14-2007 01:54 PM in reply to: montero1
Sorry must have posted while you were.
Thanks for your patience.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
