AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
File locking
3 REPLIES 3
genem
478 Views, 3 Replies
File locking
Using AutoCAD MEP 2014, SP 1 here. Lately, I am having problems where after doing some work, if I try to save the file, I get an error message that the file is locked.
I am using AutoCAD in the same manner as I have for years and years, and never had this issue before.
It seems to have started after SP-1?
Anyone with ideas?
Oh...here's a good one too.....click on Spell Check when writing one of these posts...AutoCAD isn't in the dictionary!!
genem@... (NNTP handle: genemarz)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 10 years
as genemarz
3 REPLIES 3
pothied
in reply to: genem
I have not heard of this issue with anyone else but can you test uninstalling SP1 and see if you still have this problem?
David Pothier
genem
in reply to: pothied
Uninstalled...rebooted.
Now I get this error:
[cid:image001.png@01CEF1C9.6475B800]
I hit close, it loads some more, and then I get:
[cid:image002.png@01CEF1C9.6475B800]
It then exits.
Standalone license.
I will try a reinstall now.
Gene Marz
Senior Plumbing Designer
Office: 319.841.1944 | Mobile: 319.310.3844
DESIGN ENGINEERS
PROACTIVE | COLLABORATIVE | TENACIOUS
www.designengineers.com<>
as genemarz
GailL
in reply to: genem
I have run into this problem before, and sometimes the.dwl still exists after you are out of a dwg. Look for the .dwl file, and if no one else is in the dwg, delete the .dwl file and see if that helps. Otherwise, SaveAs to a new name will save your work too. Not sure if this is exactly your problem, but this worked for me.
”Boost
