AutoCAD MEP General
New Member
Message 1 of 4 (248 Views)
FONT CHANGES
248 Views, 3 Replies
03-16-2013 06:45 AM
May I know why font changes each time I copy from the paper space in an old sheet to a new one?
Valued Contributor
s.lawrence
Message 2 of 4 (223 Views)
Re: FONT CHANGES
03-18-2013 12:44 AM in reply to: Folatwins
Check the style of text you are cutting and pasting. Type ST at the command line.
You'll probably find that the style you are copying exists in the new drawing and uses a differnt font.
New Member
Message 3 of 4 (214 Views)
Re: FONT CHANGES
03-18-2013 08:17 AM in reply to: s.lawrence
Thank you for responding. Does it then mean that if I'm copying an existing font it will be overridden? I need more clarifications please. Thanks.
Valued Contributor
s.lawrence
Message 4 of 4 (212 Views)
Re: FONT CHANGES
03-18-2013 08:24 AM in reply to: Folatwins
If you type 'ST' at the command line and press enter, it will bring up the 'Text Style manager box. In the left window will be a list of the existing styles in your drawing. With each of these styles will be associated a font name, a height, width factor etc. If you copy text of this style (for example, style 'Romans') into a drawing which also contains the same style name ('Romans'),when you paste the text will inherit the style in the new drawing.
There may be a couple of other reasons this may be happening, but I would imagine this is the correct one..
Stu
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
