AutoCAD MEP General
Distinguished Contributor
Message 1 of 6 (338 Views)
FLOOR SLAB "MISSING"
338 Views, 5 Replies
03-15-2013 09:13 AM
I created a floor and roof slab for sectioning purposes.  when I cut a section thru duct, pipe, columns, beams, everything is there but the floor slab.  When I go to a 3d view, I can get it to find it, but in plan view nothing.
I even delete the roof slab and the floor slab is not there.
bottom of roff slab 10'-3", top of floor slab 0" with -6" thickness.
What am I missing?
Product Support
Message 2 of 6 (277 Views)
Re: FLOOR SLAB "MISSING"
03-19-2013 05:56 AM in reply to: Kayrondad
I'm not sure what you are missing. Can you post the file so I can take a look at it and see what you are missing?
David Pothier
*Expert Elite*
Keith.Brown
Message 3 of 6 (269 Views)
03-19-2013 10:19 AM in reply to: Kayrondad
If I start a new drawing from the out of the box us imperial template I can create a slab and see it in plan view.  Additionally i can create a section and have the slab appear in the section.  If you are not experiencing the same results then you need to check your display settings for the slab object in your current display representation.   Let us know if you need assistance doing that.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
Product Support
Message 4 of 6 (254 Views)
03-20-2013 08:43 AM in reply to: Kayrondad
Are you still having a problem with getting your floor slab to show up in a section? If so, I would like to help you get it to show up and the fastest and simplest way would be to post attach a dwg with the objects in question so that I can determine why the slab isn't showing. If I don't hear back, I will assume that you got it working.
David Pothier
Message 5 of 6 (251 Views)
03-20-2013 08:51 AM in reply to: pothied
No solution yet.  I have been swamped and just short cutted around it to make it work.  The drawing is too large so I cannot attach it unfortunately.
Product Support
Message 6 of 6 (245 Views)
03-20-2013 10:52 AM in reply to: Kayrondad
Instead of sending a large file, perhaps you could block out a small section of the drawing and save it to a seperate file and send that.
David Pothier
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
