Dear Vijay, Thanks a lots
Here's the procedure what we do:
1- Go to FORMAT - Style Manager - Electrical Objects - Device Styles and click New Style
2- On the General tab add the name you would like to call the device
3- On the Design Rules tab pick the type of device, add a layer key and set how you would like the wire to cleanup.
4- On the views tab Add a view called Plan, Pick your schematic view block on the view block pull down, select plan in the display representation, choose top and bottom on the view directions and click Use Annotation Scaling under scale.
6- If created a 3D block create a second view called Model, Pick your 3D block, select model in the display representation, choose everything but top and bottom, and don't check the Use Annotation Scale.
7- On the Connectors tab, click add a connector and fill in the information for the connector.
8- Finally, we can add a classification if we like and change the way the object is displayed.
Hope this is the method of doing the new device and changing the schematic symbol to device style ? is int it ?
we may have better solutions in 2007.1 ?
Best regards...
Binu KEO
Kuwait
