You can use two different system definitions as Gene describes. Make sure
that the systems uses the same System Group so you want have any
disconnections due to system missmatch. Do a display override on the system
used for the ducts that should be displayed with a single line and turn off
the contour line. Now you can draw ducts using the different systems and
even connect them to each other. One limitation is that you can't modify the
system on one segment in a duct run without changing all segements; you have
to draw the ducts with the right system in that case.
/Bosse
"AJSCE"
wrote in message
news:A7FE0F36821718D549FBB82EB35ABC3B@in.WebX.maYIadrTaRb...
> I think what he is asking about being able to do is have duct appear as
both
> single line and double line in the same window/viewport on the same
> sheet/tab. I have not tried that here, telling everyone that drawings had
> to be either single line or double line but not mixed (in the same
> viewport). After thinking about it, perhaps it could be done using
> overrides. Would have to create new system definitions assigned to their
> own new layer key styles. (for example: something like supply single line,
> supply double line, return single line, return double line, etc...).
Then
> pick a display configuration or create a new one as needed where you could
> be sure your overrides on the systems would display as wanted (example:
> supply single line would only show center line while supply double line
> would have most turned on/set to show). I will check with the owner here
> and see if it is something he would be interested in exploring and repost
if
> I actually get into it and find a way to work it out or get close.
Perhaps
> someone else has already found a way to accomplish this in an easier
fashion
> than creating near duplicate systems also, this was just off the top of my
> head without the program in front of me.
> Gene Boone
> "jason martin [Autodesk]" wrote in message
> news:EB4F82478FB357121B6CDC054635B6F0@in.WebX.maYIadrTaRb...
> > Hi Matt -
> > What's a 2 Line duct style? A duct style is neither 2 Line or single
line
> > but just a style.
> > If your ductwork is all "slip joint" for example, then any segment that
is
> > the same size is by definition the same style. If you have a 24x24
segment
> > in one part of the drawing and a 24x24 segment in another part, applying
a
> > style override won't work, because they are the same style.
> > Is it possible to do what you want? Maybe, I'm not sure I understand
what
> > that is yet???
> > jason
