style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">On
the duct settings dialog box. Lower right hand corner. Check user routing,
then define the elbow angle you prefer, 15degrees.
"Dave Griffith (Griff)" <
href="mailto:djg@inel.gov">djg@inel.gov> wrote in message
href="news:082CA6A61E0B290E2C8E82EB2A5220E8@in.WebX.maYIadrTaRb">news:082CA6A61E0B290E2C8E82EB2A5......
I appreciate the
reply, but I am still not able to do this. By duct settings dialog box,
are you refering to "Add Ducts" dialog box? I can set these options
in the dialog box but I don't get the desired result when I try picking points
and changing the duct elevation. Would you mind sharing the steps you
take to draw this?
face=Arial>
"jmcfaddn" <
href="mailto:jody.mcfadden@alcatel.com">jody.mcfadden@alcatel.com>
wrote in message
href="news:f18df1a.0@WebX.maYIadrTaRb">news:f18df1a.0@WebX.maYIadrTaRb...
15degrees.
"Rob Ward" <robw@vhv.com> wrote
in message
href="news:A329F63F04016D0CDDD81D435956DB4B@in.WebX.maYIadrTaRb">news:A329F63F04016D0CDDD81D43595......
Dave,
The best way that I have found to do this is to
draw the duct at your starting elevation of 10' turn your ortho on and copy
that section to the left or right(far enough to show a good sized gap between
the two). Then move the copied section up 2' to your ending elevation of
12'. Open your "Add Duct" dialog box and put a check in the "Used
routing" box (make sure that 15º is one of your available angles) start you
duct on the node of your first duct and then snap to the node of the upper
duct. When asked to connect, do so and if you look at the command line
you should be given the option accept the proposed layout or you can toggle
through you options by choosing next.
hope this helps,
~Rob
href="news:082CA6A61E0B290E2C8E82EB2A5220E8@in.WebX.maYIadrTaRb">news:082CA6A61E0B290E2C8E82EB2......
I appreciate the
box, are you refering to "Add Ducts" dialog box? I can set these
options in the dialog box but I don't get the desired result when I try
picking points and changing the duct elevation. Would you mind sharing
the steps you take to draw this?
face=Arial>
"jmcfaddn" <
wrote in message
15degrees.
href="news:36CB0C41B3778C065BF9712571CED090@in.WebX.maYIadrTaRb">news:36CB0C41B3778C065BF9712571C......
Thanks for the reply. I can get
it to work, but I can't believe it is this difficult to do. I told the
guys around here that there has to be a toggle or something somewhere that
would allow you to just pick points and then if you change the elevation the
program would either give you the options for the slope of the transition or
it would have been a preset somewhere. Oh well, maybe in the next
release.
in message
href="news:A329F63F04016D0CDDD81D435956DB4B@in.WebX.maYIadrTaRb">news:A329F63F04016D0CDDD81D435......
Dave,
between the two). Then move the copied section up 2' to your ending
elevation of 12'. Open your "Add Duct" dialog box and put a check in
the "Used routing" box (make sure that 15º is one of your available angles)
start you duct on the node of your first duct and then snap to the node of
the upper duct. When asked to connect, do so and if you look at the
command line you should be given the option accept the proposed layout or
you can toggle through you options by choosing next.
hope this helps,
~Rob
href="news:082CA6A61E0B290E2C8E82EB2A5220E8@in.WebX.maYIadrTaRb">news:082CA6A61E0B290E2C8E82E......
I appreciate the
these options in the dialog box but I don't get the desired result when I
try picking points and changing the duct elevation. Would you mind
sharing the steps you take to draw this?
face=Arial>
"jmcfaddn" <
wrote in message
routing, then define the elbow angle you prefer,
15degrees.
