AutoCAD MEP General
Active Contributor
reno323
Message 1 of 3 (517 Views)
Display Representation Pipe Fittings
517 Views, 2 Replies
10-06-2011 07:19 AM
For some reason some of my pipe fittings and rise/drops are coming in with a solid hatch. Does any one have an idea why this would be? I have attached a picture.
Thanks.
Keith.Brown
Message 2 of 3 (504 Views)
Re: Display Representation Pipe Fittings
10-06-2011 03:33 PM in reply to: reno323
Make sure you don't have a system overide on some of your piping systems. This could possibly be your problem. Also check your display by elevation settings as this could also cause your problem.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Contributor
reno323
Message 3 of 3 (489 Views)
10-07-2011 08:33 AM in reply to: reno323
Display by elevation is not enabled. There are overrides but it is demo pipe so that is just for the hatch. It has to be some sort of glitch because only some of the fittings have a soid fill. It is not consistent at all. Is there a hotfix out there somewhere? I am using ACAD MEP 2012 with the new service pack.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
