Hi Matt,
You should not see the System as a fourth level in the display hierarchy
that are above the Style in the hierarchy. I would rather say that the
System override is used instead of the Style and Object override. As long as
you don't override the display on the Style or Object the display settings
from the System are used. But if you override the display on the Style or
Object the normal ADT hierarchy is used and the System display settings are
ignored.
I hope I manage to clarify how it works...
/Bosse
"Matt Dillon" wrote in message
news:FCBE1EE70EA1FB525B06906AF64AF715@in.WebX.maYIadrTaRb...
> It has been awhile since I've been involved with ABS - Since R1, actually,
> and I am getting back up to speed on it. I have a question concerning
ducts,
> duct styles and systems regarding display control
> Typically ADT display control works with a 3-level heirarchy - Default,
> overriden by Style, overriden by Object.
> With ABS system definitions, it appears that a 4th level is inserted -
> Default, overriden by SYSTEM, overriden by Style, overriden by Object. Is
> that correct?
> Matt Dillon
> Assistant Moderator: Autodesk Discussion Forums
