AutoCAD MEP General
Member
Ostergren
Message 1 of 3 (69 Views)
Disk space on "C" drive +
69 Views, 2 Replies
06-09-2003 01:44 AM
1st Question,
A full load on ABS4 appears to require a minimum of 900+MB on my "C' drive even when using the alternate install location on "D". My "C" partition is down to just enough space to load the program with no spare room. Will I have to repartition the drive to allow more room on "C" or is ther a work around. I have plenty of room on other partitions.
2nd. Question,
Page 8 of the Concepts Guide says that "some features from Architectural Desktop 2004 are available." I was under the understanding that the ABS included a fully operational base of ADT4. If only "some" of the features are available, which features are not included with ABS4. My basic question is "will I lose any of the existing features of ADT3 when I load ABS4?"...
3rd. Question,
Somewhere in my reading (either in the Guide or info on the new disk) I read that we can use a parallel copy of ABS3 for only 60 days after loading ABS4. Is this just a function of the subscription program or am I misreading something? I have two seats of ABS3 - would this apply to both seats or could I load my second seat onto the same machine with ABS4 and not have the 60 day limit? The reason for this question is related to Question 2 above i.e.. if ABS4 includes a fully functioning ADT4 then I have no reason to keep ABS3.
John Ostergren
*[Autodesk], Lars-Ake Johansson
Message 2 of 3 (69 Views)
Re: Disk space on "C" drive +
06-09-2003 03:15 AM in reply to: Ostergren
1. The content
installed under 'Documents and Settings\All Users\Application Data\Autodesk'.
That catalog is in most cases located on the same drive as the operating system.
For a full install of ABS4 it's about 900 Mb.
There is also some files installed under 'Program
Files\Common Files\Autodesk Shared' (about 100 Mb). That folder is in most cases
also located on the same drive as the operating system.
You could move the content folders after
installation but it will require that you update your profile with the new paths
to these files.
2. Yes, all features of ADT is available. Read the
thread 'ADT Setup' for info how to set up your ABS to work like
ADT.
3.  It was in the License agreement. Yes,
if this is an upgrade, you can only use the previous version for 60
days.
style="MARGIN: 12pt 0in 0pt; TEXT-ALIGN: justify; mso-pagination: none">
face="Times New Roman">
style="LAYOUT-GRID-MODE: line; COLOR: black; LETTER-SPACING: 1pt">Upgrades:
style="LAYOUT-GRID-MODE: line; COLOR: black">
style="mso-spacerun: yes">
style="LAYOUT-GRID-MODE: line; COLOR: black">If this Software is labeled as an
upgrade (“New Version”) to software previously licensed to you (“Previous
Version”), you must destroy all copies of the Previous Version,
including any copies resident on your hard disk drive, and upon
request by Autodesk return any Documentation to Autodesk or your Autodesk
Authorized Reseller within sixty (60) days of acquiring
the New Version
.  Autodesk
reserves the right to require you to show satisfactory proof that the Previous
Version has been destroyed. In the event Autodesk or an authorized third-party
in connection with the Software licensed to you hereunder provides you
additional software that supplements or extends the Software, that additional
software shall be subject to the terms and conditions of this Agreement unless
otherwise specified at the time of delivery.
face="Times New Roman">Notwithstanding the foregoing, you may retain and need
not destroy the Previous Version and may use the Previous Version solely if
necessary for the purposes of (1) installing the New Version hereby licensed and
(2) for archival (backup) purposes in order to reinstall the New Version hereby
licensed if the initial installation fails.
Under no circumstances may you operate
the Previous Version.
Regards
Lars-Ake Johansson
Autodesk BSD QA
1st
Question,
2nd. Question,
ABS4?"...
3rd. Question,
keep ABS3.
John Ostergren
Member
Ostergren
Message 3 of 3 (69 Views)
Re:
06-10-2003 02:13 AM in reply to: Ostergren
Lars-Ake,
Thanks for the reply.
As to:
Item #1, I was able to move about 850MB (enu folder) to another drive and reset the paths very easily. Seems to work fine. No apparent slow ups.
Item #2. After I figured out the pull-downs, the set up to use ADT was very straight forward.
Item #3. Since I have two licensed copies of ABS3 (ADT3.3)and this wagon only has one mule (me), and a Subscription for only one seat. I figure that I could continue to run the ABS3 seat without the subscription since it should be totally separate from the ABS2004 Subscription. If this is not correct please let me know before my 60 day limit runs out.
I may need to keep two working copies until all of my ADT3.3 clients upgrade to ADT2004. I have contract clauses that require me to work on and "return" drawing files in their format. Saving as a 2000/2002 file without the objects does not cut it.
Another note: The full 2004 program loaded very smooth and easily. I set it up as am ABS3 interface to make starting out easier. I am also impressed by the smaller files - most of the two dozen or so files that I have already converted are about 40% of the original ABS3 file sizes...
Thanks again,
John Ostergren
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
