style="MARGIN: 12pt 0in 0pt; TEXT-ALIGN: justify; mso-pagination: none">
face="Times New Roman">
style="LAYOUT-GRID-MODE: line; COLOR: black; LETTER-SPACING: 1pt">Upgrades:
style="LAYOUT-GRID-MODE: line; COLOR: black">
style="mso-spacerun: yes">
style="LAYOUT-GRID-MODE: line; COLOR: black">If this Software is labeled as an
upgrade (New Version) to software previously licensed to you (Previous
Version), you must destroy all copies of the Previous Version,
including any copies resident on your hard disk drive, and upon
request by Autodesk return any Documentation to Autodesk or your Autodesk
Authorized Reseller within sixty (60) days of acquiring
the New Version. Autodesk
reserves the right to require you to show satisfactory proof that the Previous
Version has been destroyed. In the event Autodesk or an authorized third-party
in connection with the Software licensed to you hereunder provides you
additional software that supplements or extends the Software, that additional
software shall be subject to the terms and conditions of this Agreement unless
otherwise specified at the time of delivery.
face="Times New Roman">Notwithstanding the foregoing, you may retain and need
not destroy the Previous Version and may use the Previous Version solely if
necessary for the purposes of (1) installing the New Version hereby licensed and
(2) for archival (backup) purposes in order to reinstall the New Version hereby
licensed if the initial installation fails.
style="mso-spacerun: yes"> Under no circumstances may you operate
the Previous Version.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Ostergren" <1st
href="mailto:osterpc@opcva.com">osterpc@opcva.com> wrote in message
href="news:f16bcae.-1@WebX.maYIadrTaRb">news:f16bcae.-1@WebX.maYIadrTaRb...
Question,
A full load on ABS4 appears to require a minimum of 900+MB on my
"C' drive even when using the alternate install location on "D". My "C"
partition is down to just enough space to load the program with no spare room.
Will I have to repartition the drive to allow more room on "C" or is ther a
work around. I have plenty of room on other partitions.
2nd. Question,
Page 8 of the Concepts Guide says that "some features
from Architectural Desktop 2004 are available." I was under the understanding
that the ABS included a fully operational base of ADT4. If only "some" of the
features are available, which features are not included with ABS4. My basic
question is "will I lose any of the existing features of ADT3 when I load
ABS4?"...
3rd. Question,
Somewhere in my reading (either in the Guide or info on
the new disk) I read that we can use a parallel copy of ABS3 for only 60 days
after loading ABS4. Is this just a function of the subscription program or am
I misreading something? I have two seats of ABS3 - would this apply to both
seats or could I load my second seat onto the same machine with ABS4 and not
have the 60 day limit? The reason for this question is related to Question 2
above i.e.. if ABS4 includes a fully functioning ADT4 then I have no reason to
keep ABS3.
John Ostergren
