Show only
Search instead for
i had to reload the part i was missing of the disk again. i had the same problem but i can't get all the other menu's that come with it to stop making duplicates. the ones i get are documentation and desktop. is there a way to get then to stop coming back?
To load the ADT Menus along with the building systems menu and keep them
from adding themselves back all the time see the thread titled "Room numbers
and ceiling grid"
jason martin
"rdgusa" wrote in message news:f1421e0.0@WebX.maYIadrTaRb...
If you change the name of the aecarchx.mnl file to something else (like
adding a .bak) it seems to correct the program wanting to add back in other
menus like the help file for ADT.
"jason martin [Autodesk]" wrote in message
news:09DD4DC0BDBD2C8176FBDB6EB822C176@in.WebX.maYIadrTaRb...
> Guys -
numbers
> and ceiling grid"
> jason martin
> Autodesk
a
There are some other "side affects" of renaming the AecArchX.mnl file that
you may experience (for example some things in the ADT menu's may not work)
since it will also disable the loading of AecArchX.lsp as well. If you don't
want to follow the steps in the previous post then you should comment out
the portion of the AecArchX.mnl file that causes the menus to "repopulate"
themselves. To do this you would comment out everything between
;;; Load Architectural Desktop menus...
"Clint Schwartz" wrote in message
news:EC26A5976DC9898BE02D8E03A96CE4E1@in.WebX.maYIadrTaRb...
other
