AutoCAD MEP General
Active Member
luxy72462
Message 1 of 6 (416 Views)
Demo Layer Plotting incorrectly
416 Views, 5 Replies
10-12-2012 09:04 AM
Can someone tell me what is going on here in MEP2013? My demo duct layer is showing up correctly in model space, but when I switch over to my layout to plot...the screen is rotating the demo hash lines from 45 degrees to 90 degrees (straight up/down). I have the weirdest things happening ever since I switched to 2013. Any help to correct this would be appreciated.demo layer.png
Product Support
Message 2 of 6 (374 Views)
Re: Demo Layer Plotting incorrectly
10-17-2012 11:13 AM in reply to: luxy72462
Is your paperspace viewport set to use a different display?  For example:  MEP Design versus MEP Basic 2-line?
Are you using an older MEP template with 2013?  Would you post a sample dwg?  The display controls the hatch orientation, so if they are different between model and paperspace, the orientation could be different.
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Autodesk, Inc.
Valued Mentor
Message 3 of 6 (369 Views)
10-17-2012 12:37 PM in reply to: luxy72462
Yes ... I just had a conversation with Joshua... as we made the same post to subscription support.
You can get around this issue in two ways... one is to remove the Annotation check box in the Hatch Tab of the Duct Plan Display Rep that is being used in your display configuration.
The other is to set the angle to 22.5... I know it does make any sense... it will be incorrect on the model tab, but look & plot correctly on the layout tab.
I believe Joshua is logging it as a defect to be checke into.
Product Support
Message 4 of 6 (367 Views)
10-17-2012 01:03 PM in reply to: mdhutchinson
Yes.  We now have our developers looking into this.  The solution for now, is to uncheck the "Annotation Scaling" checkbox on the Hatch tab of the object display components.  See attached image.
Hope this helps,
Joshua
Joshua Benoist, PE
Product Support
Autodesk, Inc.
Active Member
luxy72462
Message 5 of 6 (364 Views)
10-17-2012 01:14 PM in reply to: luxy72462
I have tried both options suggested and neither is working. I opened up my 2012 version to see what the settings were on that one (as it is working correctly) and there is no annotative tab for 2012 under hatching. I have even gone to a new drawing and this is only happening on the demo layer in plan space. If I just do a plot off my model space it shows up correctly but then I am missing all my other documents off my plan view. So I would have to say its something corrupt in the logic in the plan space with the hatching. I am about ready to uninstall and reinstall the program and see if it fixes the glitch. It sucks because I can't even open up some of the work I have in 2012 and make it look correct because of the backwards incompatibility from 2013.
Valued Mentor
Message 6 of 6 (362 Views)
10-17-2012 01:50 PM in reply to: luxy72462
See the attached.
Depending on whether your Display is controled at the Duct Style Level or globally at the Drawing Level.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
