AutoCAD MEP General
Valued Mentor
Message 1 of 5 (634 Views)
Defpoints Layer Color changed ?
634 Views, 4 Replies
10-12-2012 07:31 AM
I wonder why the color of Defpoints Layer changed from white to 140?
Product Support
Message 2 of 5 (597 Views)
Re: Defpoints Layer Color changed ?
10-16-2012 03:34 PM in reply to: mdhutchinson
  • Did this happen only in one particular drawing, or is it happening for all of your drawings?
  • Are you able to change the color back to whatever you want?
I looked through our Development write-ups, but I didn't find any mention of that particular behavior.
Zac Travis
Valued Mentor
Message 3 of 5 (589 Views)
10-17-2012 06:15 AM in reply to: mdhutchinson
The standard out of the box default installation of AutoCAD MEP has defpoints color 140... see all of the installed templates at C:\ProgramData\Autodesk\MEP 2013\enu\Template
I checked all of the AECB*.dwt files... every one of them have Defpoints layer color set to 140.
Product Support
Message 4 of 5 (580 Views)
10-17-2012 03:43 PM in reply to: mdhutchinson
After checking with other Development and Support resources, I found that:
For MEP and ACA 2013, we eliminated most built-in layers from the templates.  The paper space viewports used to be on a layer that we decided to eliminate.  We wanted the viewports to stay the same color (140) and be on a non-plottable layer, so Defpoints made the most sense.
Does this cover your original question?
If you want to bring forward the templates from previous versions of MEP or ACA, that can be done, or you can modify the shipping templates from 2013 to suit whatever your needs might be.
Zac Travis
Valued Mentor
Message 5 of 5 (567 Views)
10-18-2012 07:46 AM in reply to: ztravis
Thanks for the explanation...
I fully understand that you can do what you want with templates...
My practice with a new release is to always create new company templates from out of the box templates. The users were asking why I changed the color of defpoints. I did not change it .. so I investigated.
Side note: I know probably 90% or more users put viewports on defpoints layer. In my oppinion, it is better practice to let AutoCAD use defpoints and refrain from putting any other objects on it.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
