AutoCAD MEP General
*Bernhardt, Kyle
Message 1 of 2 (63 Views)
Default Pipe and Duct Systems
63 Views, 1 Replies
08-20-2003 12:52 AM
I have created a template file that defines all the necessary systems for my
BS objects, and when our users start a new drawing with the template all the
systems come in correctly. The problem is that when you start using ABS on
an existing CAD drawing without the template, these systems do not exist,
only the default ABS systems. I see that there is a file under "Documents
and Settings\...\enu\Styles\Imperial\" called "Pipe System Definitions.dwg".
Here the default systems are defined. Instead of changing this file on
every computer, I'd like to have a version of this file on our network that
is referenced by every computer. Even better, I'd like to move the whole
"Styles" folder to the network. I do not see this folder in the search
path, so I cannot simply move it and change the path, where is the reference
to the path where these systems definitions files are located? I need to be
able to change this setting.
Kyle Bernhardt
Mechanical Engineer
Dagher Engineering
29 Broadway
New York, NY 10006
*[Autodesk], jason martin
Message 2 of 2 (63 Views)
Re: Default Pipe and Duct Systems
08-20-2003 01:51 AM in reply to: *Bernhardt, Kyle
Hi Kyle -
The system defs aren't pulled from any of those files. Those files are there
as additional / backup style definitions, but are not pulled in
automatically by the program. If you want to get system defs in existing
drawings you should be able to simply insert a drawing with the system defs
in it into the current drawing.
jason
"Kyle Bernhardt" wrote in message
news:CAFCA16EFD18EB26A779104B80A3118E@in.WebX.maYIadrTaRb...
my
the
on
Definitions.dwg".
that
reference
be
> Kyle Bernhardt
> Mechanical Engineer
> Dagher Engineering
> 29 Broadway
> New York, NY 10006
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
